I know what ya mean.
Sometimes when you get some of these hair pullers(probably why I have none left) you have to wonder why we do this for a living.
That is so true. I always felt like us techs who do the electrical and dianosis work were way underpaid. But I did it for about 40 years.
You might also make sure you have 5 volts at the 5 volt senors wires. And at the pedal assembly also as I had a broken wire do that before. None of the sensors were getting 5 volts on the #one 5 volt circuit because I had a open circuit in the 5 volt wire between the PCM and the first sensor that circuit fed. The PCM will still see 5 volts all the time since it has an open circuit on the 5 volt wire. If you dont get 5 volts at the sensors check it at the PCM and see what you get. If the 5 volt circuit was shorted the volts would show 0 even in the PCM. Ron
