Before you do anything unhook the battery for about 5 minutes. Then hook it back up and see if it starts. I had a controller lock up and do that. On some if you just power it down for a few minutes and wake everything up it would then work normal and no other problems were found. I had a couple like that where Chrysler tech line told me to just let them go and dont replace anything. I will say none of them came back. Ron
