What do the APP sensors read when you move the gas pedal with them hooked up as they should change. 5 volts at rest does not sound right. Ron
Sounds like its time for a new pedal.
The voltage on sensor 1 goes in the opposite direction than sensor 2 does when the pedal is depressed.
