Re: Battery cutoff switch and msd, car wont die
[Re: 64hemi330sedan]
#1478097
08/03/13 02:02 PM
08/03/13 02:02 PM
Posts: 1,062 Amherst,NY
challengermike
Amherst,NY
The diode idea didnt work I just tried it. And a solenoid wont either do to it needing a power loss to kick it off and nothing losses power with the alt powering it. I guess I will just run the alt wire and msd directly to the bat itself. I do like the idea of fuses on both sides of the alt line. And for what it's worth I tried the msd on the back of the alt and with the new box it didn't die either. Maybe because it's digital and not analog like the old box. I don't know why with the old box it would kill the car.
the diode will only flow power one way.turn it around and see if that will do it.if its wired the wrong way it wont work.
I checked it before I put it on. I had it so the power would only flow to the alt. If I flipped it other way my alt wouldn't charge. And it was charging when it was on there. I do understand now why a diode wont work. The power isn't going backwards but the way I have it wired its making a loop that keeps everything powered. Im sure the only way to cured this is to wire the alt and msd to the pos side of the battery like mr p body said.
Entire Thread
challengermike
08/02/13 01:31 AM
Plymouth340
08/02/13 01:34 AM
70AARcuda
08/02/13 01:48 AM
Jeepmon
08/02/13 02:12 AM
challengermike
08/02/13 02:51 AM
70AARcuda
08/02/13 04:31 AM
MR_P_BODY
08/02/13 04:36 AM
Jeepmon
08/02/13 05:10 AM
6bblFLASH
08/02/13 07:33 AM
70HemiGTX
08/02/13 07:46 AM
challengermike
08/02/13 12:00 PM
Jeepmon
08/02/13 11:47 PM
70HemiGTX
08/03/13 05:12 AM
340B5
08/03/13 06:09 AM
challengermike
08/03/13 01:56 PM
MR_P_BODY
08/03/13 02:28 PM
challengermike
08/03/13 03:53 PM
RobX4406
08/03/13 04:24 PM
MR_P_BODY
08/03/13 04:32 PM
challengermike
08/03/13 04:49 PM
11secdart
08/03/13 05:27 PM
64hemi330sedan
08/03/13 05:45 PM
challengermike
08/03/13 06:02 PM
64hemi330sedan
08/03/13 07:08 PM
