Re: Battery cutoff switch and msd, car wont die
[Re: challengermike]
#1478090
08/03/13 10:28 AM
08/03/13 10:28 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I put a diode in my field wire,that fixed mine
Good idea
I may try this today. I have 1 that came with the msd box. Not sure if it will work ok with the resister but I will give it a try. I like the idea there is no power in the car with the disconnect switch off.If this doesn't work I may try running the msd off a relay.
On the 4 post master.. I dont know how many amps it can handle but if you ran the field wire to the small post it will do the same(any way to turn off the alt.. but if you isolate the large alt hot lead I have never seen a issue (using isolated clamps to hold it on the frame)... I prefer to do it the easiest way possible because if it brakes down at the track you want to be able to fix it easy.. thats why I dont run a diode or a solenoid to kill it... the old KISS system.. if you wanted you could run a 100 amp fuse at each end of the alt lead(1 at each end would cover a short anywhere on that line).... JMO
Entire Thread
challengermike
08/02/13 01:31 AM
Plymouth340
08/02/13 01:34 AM
70AARcuda
08/02/13 01:48 AM
Jeepmon
08/02/13 02:12 AM
challengermike
08/02/13 02:51 AM
70AARcuda
08/02/13 04:31 AM
MR_P_BODY
08/02/13 04:36 AM
Jeepmon
08/02/13 05:10 AM
6bblFLASH
08/02/13 07:33 AM
70HemiGTX
08/02/13 07:46 AM
challengermike
08/02/13 12:00 PM
Jeepmon
08/02/13 11:47 PM
70HemiGTX
08/03/13 05:12 AM
340B5
08/03/13 06:09 AM
challengermike
08/03/13 01:56 PM
MR_P_BODY
08/03/13 02:28 PM
challengermike
08/03/13 03:53 PM
RobX4406
08/03/13 04:24 PM
MR_P_BODY
08/03/13 04:32 PM
challengermike
08/03/13 04:49 PM
11secdart
08/03/13 05:27 PM
64hemi330sedan
08/03/13 05:45 PM
challengermike
08/03/13 06:02 PM
64hemi330sedan
08/03/13 07:08 PM
