Re: Battery cutoff switch and msd, car wont die
[Re: challengermike]
#1478093
08/03/13 12:32 PM
08/03/13 12:32 PM
Posts: 52,972 Romeo MI
MR_P_BODY
The diode idea didnt work I just tried it. And a solenoid wont either do to it needing a power loss to kick it off and nothing losses power with the alt powering it. I guess I will just run the alt wire and msd directly to the bat itself. I do like the idea of fuses on both sides of the alt line. And for what it's worth I tried the msd on the back of the alt and with the new box it didn't die either. Maybe because it's digital and not analog like the old box. I don't know why with the old box it would kill the car.
Is your alt a single wire(hot only) or is it using a external regulator.. if it has a external regulator you have 2 field wires... one is a sense wire and the other is keyed hot.. if you break the keyed hot lead you then kill the alt... here is a simple wiring diagram of how the system works
Entire Thread
challengermike
08/02/13 01:31 AM
Plymouth340
08/02/13 01:34 AM
70AARcuda
08/02/13 01:48 AM
Jeepmon
08/02/13 02:12 AM
challengermike
08/02/13 02:51 AM
70AARcuda
08/02/13 04:31 AM
MR_P_BODY
08/02/13 04:36 AM
Jeepmon
08/02/13 05:10 AM
6bblFLASH
08/02/13 07:33 AM
70HemiGTX
08/02/13 07:46 AM
challengermike
08/02/13 12:00 PM
Jeepmon
08/02/13 11:47 PM
70HemiGTX
08/03/13 05:12 AM
340B5
08/03/13 06:09 AM
challengermike
08/03/13 01:56 PM
MR_P_BODY
08/03/13 02:28 PM
challengermike
08/03/13 03:53 PM
RobX4406
08/03/13 04:24 PM
MR_P_BODY
08/03/13 04:32 PM
challengermike
08/03/13 04:49 PM
11secdart
08/03/13 05:27 PM
64hemi330sedan
08/03/13 05:45 PM
challengermike
08/03/13 06:02 PM
64hemi330sedan
08/03/13 07:08 PM
