Quote: Ok. pulled it all. Bell housing # 2892513. Flywheel 13 1/4 diameter. 130 tooth. ??????
Are you asking if that one is a 130 tooth or you have confirmed it is by counting the teeth now that it is out ?
I have looked at pictures of original flywheels and it's hard to tell if that ring gear is in the right place or not. I have a bunch of flywheels at home but I keep forgetting to drag one out, I'll look tonight if no one comes up with a picture and measurement.
No it IS a 130 tooth. Heres a pic from the side of the flywheel
