Quote: FWIW I believe the Magnums with the pedestal rocker are considered to be the longest lasting and best performing stock standard performance SB's. Maybe lowest cost and done right?
Most of the durability comes from the EFI. Those engines don't have carburetors washing down cylinder walls with unburned fuel.
We are brothers and sisters doing time on the planet for better or worse. I'll take the better, if you don't mind. - Stu Harmon
