I've always been a FAN of Centr. Blowers.
BUT belt slip is a BIG issue when pushing for much over 12psi.
Unfortunately hardly anyone makes a pulley setup for a fully optioned (A/C, PS, etc) street Mopar application that will hold anything passed 10-12psi.
There are a few Cog Drive systems out there that will hold some serious boost but built only for LA based small blocks and limited accessories
Yes, belt slippage is an issue. Ya gotta runem TIGHT!! Per Procharger, with very little or no belt tensioner free play.
you can buy a kit for a BBC and make it work for about 1/2 what a mopar kit would run. AMHIK.
Can you elaborate on that a little? I have seen you mention it before, but am curious to know what parts would cross over and what has to be changed/modified?
