Quote: good running I was goning to say if all goes well you should pick up 4-5 tenths. I wonder if you went up on the gear if that would help? You have 2.76's correct? maybe try 2.94's or 3.23's Does anybody make a 3.08 for an 8.75???
The shallow gear loads the turbo harder than a steeper gear BUT he is giving up low end acceleration.. there is a happy balance with the gears... I know he put in what he had laying around... the gear that was in it when I put the turbo on it was SCARY noisy with clunks and what not(it was the worst sounding gear I ever heard that was still rolling)
can't believe goint to a 2.94 or 3.23 would hurt anything... did he switch to a glide???
