I can absolutely tell you how to professionally do the letters. I did mine and it looks fantastic.
I went to the hobby store and bought a bottle of Testors white model paint, in the small square jar, and a bottle of Testors brush cleaner, and a small, cheap brush. About 7-8 dollar investment.
The only other thing you need is a brand new pencil with an unused eraser on it.
I lightly chucked the heater panel into my vise, with some towels for protection, just to hold it vertical and steady, letters facing up. All you need the brush for is to daub a small blob of the white paint onto a piece of scrap cardboard. Lightly daub the pencil eraser into the blob, then lightly wipe the eraser onto the cardboard, so that all you have on the end of the eraser is a light film of white paint. Lightly start touching the raised letters, with the eraser at a perfect 90 degree angle to the letters. Don't try to completely cover every spot you touch on the first daub. Just keep repeating the above steps.
Took me a little experimenting, but once I got the procedure perfected, took about 10 mins. to make the letters look perfect. Too much paint on the eraser, and the excess paint will run down the sides of the raised letters. If that happens, use the brush cleaner and a rag or paper towel to wipe the boo-boo, and go at it again with less paint on the eraser.
As for the edge, yes it's chrome. I used the silver/chrome paint pen. Not as chromey as it should be, but I'm happy with the results. As for the black, I can't help you. I didn't repaint my black, just scrubbed it real good with cleaners before I painted it.
Good luck and I know you will be happy with the results...
