So I could basically wire it up like a nitrous activation with the exception of the WOT switch. Just use a vacuum switch.
The big thing I am looking at is street driving. I need to fog whenever the engine is under load. A simple 1 gallon jug is not going to cut it. I also need to look at multiple stages to cover different amounts of load.
Again similar to nitrous just instead of timers it would be MAP switches.
Am I still clueless? Probably
Leon
Career best 8.02 @ 169 at 3050# and 10" tires small block power.
