Well I think I have found a solution. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
I drilled a passage from the side of the carb. main body between the venturi`s which intersects with a hole coming up from the bottom thru the baseplate inline with the air cleaner stud. ![](/ubbthreads/images/graemlins/sawzall-smiley.gif) This base already has a 5/8 recessed hole in the center of the throttle blades. I will drill it thru and tap 1/8NPT and thread a nozzle there spraying straight down into the top of the blower. The outside passage will also be tapped to plump the high pressure water/meth. The rest will be like any other install. ![](/ubbthreads/images/graemlins/wrench.gif)
I will take some pic`s once its done.
Sweet idea. Please remember to post those pics when youre done!
What carb are you currently using?
For my B&M blower, I'm thinking of using one of the holley 750 supercharger carbs.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
