Make sure you look good at the upper control arm mounting tabs that they didn't crack where they are welded to the body. My car I have now had bad strut rod bushings and it broke off the tab that the upper arm bolts into because of the back and forward motion of the lower control arm. The person that owned it before me crashed at the track due to it busting off. This is an a body but im sure it still applys to a b body.
