Mopar-Mike, did you mock this up all the way? What was the distance from the back edge of the balancer to the timing cover? 1/4 inch or 1 inch? 1/4 or a little less is about the correct depth. Even with my KB gear drive and Milodon Gear drive, the space is very small.
