Ron at Diamond Pistons said that they are interested in creating an "off-the-shelf" piston for the 383/431 Stroker. It would come in a flat-top and a dish configuration. It would be designed using the 440 rod length. However, after reading the previous posts and maybe some research about the small bore/short rod phenomenon, they may want to look at the 383 rod also.
