All,
I have received emails from most of the piston manufactures on the market. Basically, they have custom pistons for $1000+. However, there were a couple of exceptions.
Ron at Diamond Pistons said that they are interested in creating an "off-the-shelf" piston for the 383/431 Stroker. It would come in a flat-top and a dish configuration. It would be designed using the 440 rod length. However, after reading the previous posts and maybe some research about the small bore/short rod phenomenon, they may want to look at the 383 rod also.
Mike at Muscle Motors Racing said he would have some sets in stock in a few weeks. The cost is $559. I bet these are custom Ross Pistons, but I’m not sure.
So if anyone out there wants to build this Stroker or thinks it’s a good idea, you had better start sending so emails to these guys an let them know. Capitalize on the opportunity.
Here are some links.
Diamond Pistons Muscle Motors Racing Thanks,
Mark Jackson
The Jackson Garage
