old racer told me at the track 1 night that a well know racer told him to turn the bolt up on top of the front shocks a even amount .. so that night I tried it on 1 pass worked.. even though my car was in need of some frontend work... car would run 7.40 at 90 mph with a 1.67 best 60'.. car would pick the wheels up about 5/6" in the air for a few feet then sit them down and spin...
What does turn the bolt up mean? Make sure the shock is loose in its mount? Sorry didnt stay at a Holiday Inn last night...
You loosen the top nut on the front shocks and then push the shock stud down as far as you can before running it that way so the shock has a little more travel before starting to extend the shock OP, if your car likes that you need softer front shocks ![](/ubbthreads/images/graemlins/scope.gif) ![](/ubbthreads/images/graemlins/Twocents.gif)
