Your control arm bushings may be binding. Take the bolts out and grease them. The lighter the front spring, 6 cyl torsion bars, the more stored energy you have with the car level. You may want to try the race torsion bar.
Your rear tire pressure could have a lot to do with this. My car would leave flat as a pancake with stock suspension. I was told by freinds the car was not spinning. Mounted a set of 28X10.5 slicks on the car with about 11 psi and she picked them up about a foot.
Leon
