Quote: I have a 68 cuda small block with 6 cyl. torsion bars and 90-10 shocks that I race. It runs 7.1" in the 1/8th. I have the bars set so the car is level and it gives no weight transfer at all. It has super stock springs with 80-20 shocks in the back. It just stays flat when it leaves. If I take a hold of the bumper and lift it will raise but it is heavy and is not "loose" by any means. Do you guys have any ideas on getting a stock front end on an a body to work the weight transfer? Thanks
