yes he told me to back the nut off a little and see what it would do.. it picked the car up some with just doing that... I would not leave it like that are run it much cause the nut may come off dep. on much you back it off.. I just did a few turns..oh I have comp 3 way on the front to.. I have took them off and they are very stiff when pushed by hand no matter what setting you have them on..now at the same time I put new control arm bushing in and ball joints and had it set up for a race alignment.. so the car itself could have been stiff as well but that little trick work for the run compared to the run before it..
![](/ubbthreads/images/graemlins/image_294343.gif)
