Quote: This thread is starting to get out of shape. OP wanted advise with porting a G3 hemi at home, on his bench, stock valves and not all the bell's and whistle's that comes with custom port's and what not's.
He also talked about a valve job and I kept in line with that. Telling him to not touch the ex. port floor isn't much advice
Pictures never hurt as you provided some too. Stock valves may or maynot have their place in his build...
Greg, basicly what you want to do by cleaning the castings up is fine, just be careful not to break into a pushrod tunnel. Reason I posted the valve job pics is because that's where alot of flow is gained, and then blending the bottom cut into the bowl. Next big power maker is the camshaft. Are you coming down to the shop? I have some Hemi stuff in if you want to check it out
