Quote: Our 345 cubed, stock stroke/stock bore, 12:1, 229/235 @.050", DP intake, stock 6.1 heads cept the intake valve was 2.10" vs the factory 2.08" made 545 hp @ 7000 rpm where we ran out of camshaft.
Barton went 9.67 in his A/SA 370 cubed G3 back in 2011. He then went 9.38 with a 392.
Most Stock eliminator 6.1/370's I've seen make 630 and change. Southland Speed while dyno testing had an idea with making the engine breath better. I manufatured a certain part for them and they picked up another 20 hp. Aother 6.1 DP I know off went 9.67 with this same mod.
Now add 56 more cubes with full boogie heads...I think 700+ hp might be doable.
