In NO way could you compare my car to a DP car, as far as comparing et's and HP. My car has a 727 in it and a dana 60 nothing fancy. Also my converter is no where near being close to where it needs to be. Mine flashes to bout 5200 and Barton told me his flashes to 6700 rpm.
So with a trick 904 and 8.75 rear and converter that would flash to 6700 I have no doubt my car would run 9.50's.....I am also only shifting my motor at 7000rpm and going thru the traps at 7200
One more thing I dont have my EFI tunned right yet etiher my 60ft so far as only been 1.38 do to my tune and converter.
So my motor in a 3200 lb drag pack car with all the tricks would appear to be making over 700 HP I would guess.
I love the not on my dyno it wouldnt make that. where is RyanJ when we need him.
