MrP, why did you use the centre oil outlet?
Would it be better to eliminate the two 90 deg turns by using the other one?
BTW I'm a cheap SOB, so could ordinary pipe fitting be used instead of the aluminum ones? Thx Matt
I just threw that on so I could prime the system..
I took it off a few minutes later after the pic...
the real set up(in car set up) comes straight out
of the block with AN then it goes forward inside the
wheel well area to the remote filter in front of the
tire and mounted on the chassis tube
