Re: Remote oil filter?
[Re: MR_P_BODY]
#1380689
02/03/13 10:41 AM
02/03/13 10:41 AM
Posts: 614 ont,canada
mopartuner
ont,canada
The Canton adapter is a nice piece if it fits,check header clearance if your headers move in tight to the block.If you buy the canton adapter remeber to buy the service kit(its only 6 bucks I think)comes with new seals.
410 pump gas solis flat tappet cam 10.95 so far
[Re: 80arrow]
#1380690
02/03/13 10:47 AM
02/03/13 10:47 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I drilled and tapped the block on my 416 in my Rampage and put the filter up towards the front(in front of the right front tire) so it was easy to get at... I had to tap the block to clear my headers and inner fender (here is a pic on the stand) ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1380693
02/03/13 03:54 PM
02/03/13 03:54 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
MrP, why did you use the centre oil outlet? Would it be better to eliminate the two 90 deg turns by using the other one? ![](/ubbthreads/images/graemlins/shruggy.gif) BTW I'm a cheap SOB, so could ordinary pipe fitting be used instead of the aluminum ones? Thx Matt
[Re: LA360]
#1380696
02/04/13 05:28 AM
02/04/13 05:28 AM
Posts: 161 New Zealand
dart6
New Zealand
I make these
![](http://i86.photobucket.com/albums/k118/W8_LA360/CAL%20Machineworks/2011-11-03133444.jpg)
tell us more and how much
[Re: MR_P_BODY]
#1380699
03/05/13 12:53 PM
03/05/13 12:53 PM
Posts: 3,422 Toronto
mshred
Toronto
Hey Mr. P and Tubtar, was hoping to get your guys input seeing you both have done this before. If I am understanding correctly and by the pic that Mr. P posted, you are running without a plate on the block and instead running a line out of the center fitting and then drilling and tapping the hole to the left of the center that usually has a plug for another line? What size are you drilling and tapping to, and what size fittings need to be used for this setup? This would be a great way for me to save some money on the canton adapter since I am doing a remote filter and cooler for my new motor. If you guys have any more detailed pics of how you did it, that would be great too! ![](/ubbthreads/images/graemlins/thumbs.gif) Thanks!
[Re: AndyF]
#1380703
03/05/13 01:51 PM
03/05/13 01:51 PM
mshred
Toronto
Plug the large center hole and then drill and tap return hole. The hole in the block is at a slight angle so you have to be careful when you drill and tap it. The biggest that you can tap those holes is 3/8 NPT so then you have to use some special adapters to get up to a #12 AN line. You can get the adapters from BLP. CV products should also have them.
Hey Andy,
Thanks for the info! Would a regular plug with o-ring be sufficient for the large center hole that needs plugging?
Also, the adapters to go from 3/8NPT to say -10 or -12, are they special adapters for oil? Or can you use any specialty AN fiting in the right sizes?
