Of course it will depend on what kind of car you are building, a restored original or a Hot Rod/Clone, etc. If it's a rarer model I'd keep it as original as possible. IMO the act of painting the bottom of the car to be all new and shiney "Jumped the Shark" a long time ago. A more factory correct look is the current trend that I see more and more these days. To me it looks even more attractive to attempt making them look as they really did. In any event I'd choose between painted and the over sprayed look of my car above, I wouldn't use any kind of Lizzard Skin or other undercoating product, it gives the look of someone trying to hide rust or other ills to most onlookers.
If you are worried about corrosion think about how you plan to drive the car. Most of these cars never see more water than the end of a hose in your driveway to wash them off occasionally, it's not likely the bottom will rot out of it if you don't coat it in some kind of bead liner/POR15/Rust shield product, especially if you do a good job of getting rid of all the rust that is there in the first place and do a proper metal prep before adding a good primer/sealer and quality paint job.
I did paint mine fully underneath and I don't regret it (yet) but I'd probably go with a more stock look if I did another. Whatever I do I will never use bedliner or anything remotely similar and would avoid undercoating as well (except for the wheelwells). I like to be able to see the metal, joints, etc. and don't like anything covering that up.
The OP's car isn't exactly a stock resto, so I'd say "fill your boots" but I'd still avoid the bedliner and similar products...just don't see the need.
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
