That's why I would not be making too many changes to what you have. Those plugs are real close to being spot on. You should really only make one change at a time. If it was my car I'd swap plugs and make a pass to the shift into hi gear. Turn it off and check them. Adjust the tune up in baby steps to dial it in. Then I'd detune it a little with a little less timing and try to enjoy beating on it for a few years
