Quote: Put the biggest nozzle in the meth inj. Run a ngk 5671-9 or 10 and let her rip. 11.8-12.0 is a good afr to shoot for on a blower motor.
Thanks for the plug recommendations. Can't keep it lit with the biggest nozzle, but I will go to the middle size. I don't monitor A/F, but looking in to a wide band unit. Thanks Duner. I do have a video of the run as I was monitoring the boost and tach gauges. Rev limiter was set at 7K and I was up against it several times. Surprised it went 10.50 as I was in and out of the throttle at the end of the run. I'll try and post it.
