Some of this stuff can be done by some simple tests like a leak down tester or a compression tester. But it also won't tell me what the bearings are going to look like or how good of shape the valve springs are in. So that stuff is just going to have to be checked!!!
Good move.......... inspect it......
if is not broke don't fix it. just have fun..........
IIRC these pistons are real heavy. I would not try and RPM the bejeezuz out of it.....
