JCFcuda,
A chunk of any metal with a hole in it when heated will cause the hole to enlarge and increase the clearance. Thus the loss of oil pressure when the pump cannot keep enough flow like at idle. When half that chunk of metal is AL then the hole becomes even larger due to heat.
Damon
