The oil pressure changes a lot with aluminum caps too. Not a major problem with aluminum rods because they are the last in the oil sequence, but mains need to maintain their clearance. Also, it's much harder to line hone with aluminum caps on an iron block since the caps cut quicker. You can make anything work but is it worth the effort? Most machinists would stay with what they know.
