When you say switching from 750s to a pair of 1050 Dominators are you saying you are running a tunnel ram with two 750 CFM carbs switching to the two 1050 CFM carbs? If so expect around 30 to 40 HP increase with both set of carbs max out on the fuel delivery and mixtures If switching from a single 750 to twin 1050 a little more HP and torque than above, 55 to 70 HP maybe I saw 30 HP going from a single 1050 Dominator on a cast single 4500 intake to two 1050 Dominators on a tunnel ram for 4500 carbs
Most of that power was the manifold change.
