the heads were the first set of mopar heads i ever bought. My goal was to make 875 NA and i was told they would work, After i decided to procharge it all i did was change the cam, pistons make a 4150 intake adapter and that was it.
Yes a engine needs to make real good power by itself or the boost won't be as big as a gain as it can be. Don't forget i don't turn this blower hard either it only see's 22lbs in the 1/8 and 24 in the 1/4. Boost is only a measurement of restriction.
