Quote: The intent of those slots is not coolant flow, it prevents air pockets getting trapped.... The intended coolant flow path is front to back around the heads the down around the rear cylinder & toward the front.... By opening the coolant passages mid way you allow the coolant to bypass the rear cylinders...
