Question about Beadlocks. I have a 2785lb Door car ( Cuda) 4 Link Front Strut Car, I Run the Goodyear D1984 32x14x15 Tire on a set of Convo Pro's the Problem is after 50-60 passes the reaction times start to drop off, Pro tree will go .00 all day long till it gets 50-60 passes then cannot get better than a .037 light, full tree same story have to change my delay box to compensate. car runs mid to high 8.40's 155-161mph, The question is will Beadlocks help the side wall last longer so I can get more runs on the tires, The contact part of the tire still has alot of life in it still.
Next question How many passes should I be getting on these tires. I do conservative Burn outs I have been replacing at about a 100-120 passes or so. Thanks for your input
The purpose of beadlocks is to keep the tire on the rim. In high speed/high horsepower cars they are preferable to screws in that regard. I doubt very much if they will extend your usable tire life. BTW we get about 15 runs on ours' before the sidewall is shot.
