well last weekend my Autometer gauge rolled over past 240ºF and was heading for the 0 again...As it idles in park for 15 minutes
Ah, that is bad assuming the gauge isn't bad. Generally, cooling issue at idle/low speed are airflow relate. Can you borrow another fan setup to verify the clutch is out?
They say there are no such thing as a stupid question.
They say there is always the exception that proves the rule.
Don't be the exception.
