200* isn't dangerously hot. But if you have a 180* t-stat, then it's unusual and may need attention. If the cooling system is working properly, it should rarely go above 180* or whatever your t-stat spec is. I run a fixed fan, but from what I understand, when you spin the fan with your hand, if the fan spins for more than 1 to 1-1/2 revolutions without resistance, or if it does not move at all, you need to replace it. Some say 3 revolutions, but that seems a lot to me. Also if there's a lot of slop in it.
