Re: 383/400 stroker - 3.90, 3.91 or 3.92 crank?
[Re: YYZ]
#1304051
09/17/12 11:47 AM
09/17/12 11:47 AM
Posts: 75,060 U.S.S.A.
JohnRR
U.S.S.A.
John, on that build did you stay with the stock BB journal size or did you have the crank turned down to use a 2.200 journal?
I ended up selling the crank before that project got finished, but it did stay with the stock rod journal size while I owned it.
It may be a wash by the time you are done if the CCJ crank needs to have the rods and mains cut undersize to fix it . the plus is it's 4340 instead of 1053 .
But also make sure the CCJ crank fits the block properly also , watch out for the crank hitting the block before the thrust bearing .
Entire Thread
YYZ
09/15/12 12:43 PM
CompWedgeEngines
09/15/12 12:49 PM
sr4440
09/15/12 01:04 PM
gregsdart
09/15/12 01:36 PM
JohnRR
09/15/12 05:28 PM
67_Satellite
09/15/12 02:01 PM
MR_P_BODY
09/15/12 02:56 PM
YYZ
09/15/12 04:22 PM
Belvedere1
09/16/12 04:52 AM
440Jim
09/16/12 03:30 PM
YYZ
09/16/12 03:57 PM
JohnRR
09/16/12 09:21 PM
RUNCHARGER
09/16/12 09:42 PM
23T Hemmee
09/16/12 09:49 PM
BSB67
09/16/12 10:28 PM
Belvedere1
09/16/12 10:31 PM
YYZ
09/16/12 10:53 PM
Belvedere1
09/17/12 03:14 AM
JohnRR
09/17/12 02:59 PM
YYZ
09/17/12 03:06 PM
YYZ
09/17/12 03:07 PM
JohnRR
09/17/12 03:47 PM
Thumperdart
09/17/12 04:05 PM
jafr
09/15/12 05:19 PM
Thumperdart
09/15/12 04:45 PM
Cab_Burge
09/16/12 04:42 AM
Evil Spirit
09/16/12 08:45 PM
Brian Hafliger
09/16/12 09:04 PM
Evil Spirit
09/17/12 03:48 AM
