Without all the info, how do you expect to make an informed decision? Get the block corrected, then you will have your answer.
Joe
If you are expecting a good level of performance and anti knock resistance from this build, measuring and doing it right is the only way. If you are running flt top pistons and will not have any quench, then you can figure compression with a deck of 9.98 and your compression should be close or less than calculated and if you chose you can live with what you get. If it is still a little high you can band aid it with a thicker gasket. There are large bore gaskets in .040 and .051.
