Any chance you have the mounts on the wrong side of the engine? Don't remember if that was even possible or not. Other possibilities may be the wrong mounts (they changed in 73, you may have the 73+ mounts instead of the 67-72s), or maybe a different years K frame is in the car. I bought the whole kit for my 69 and had no problems.
When i was installing a bigblock for the first time in my charger i had the mount brackets on the block on the wrong side and had the same problem you are having . If it were me i would swap the block brakets ant try it again ! cheepest thing to start with .
1969 Dodge Charger
1969 Dodge Superbee
