Are the mounts on the front side of the ears on the block?
I think if the mounts are on the front side of the bosses, the motor would be too far back. Mine are on the rear. I'm gonna stick with wrong year mounts or wrong K Frame in the car. Schumacher should be able to give you some insight into what to look for to determine which K frame you've got. I don't think the bosses were ever changed on any of the blocks, so it would have to be the year of the K frame that determines which mounts you need.
