Wow, thanks John.
Just a few questions. I am using the old starter button. I assume the wire from the start switch replaces the wire from the starter button to the Ford relay. Also, it was hard to read, does the wire going to the starter solenoid go to the start wire (small wire) or the battery cable wire (I am guessing the small wire)?
Can I get this at NAPA?
