personally I would use a mopar relay since you are using a mopar engine and they are set up for the mopar NSS.
ford has a different set up for Neutral, I believe it is on the column or on the shifter.
the Mopar one is much easier.
mopar starters have 2 wire.
ford only uses 1 wire (battery cable)
is there a NSS on your column or your shifter?
