When using the Ford style firewall solenoid you can't use the ones that have the "I" and "S" terminals, you have to get the type that has two un-labled terminals and then run the Start wire to one terminal and the other terminal goes to the center pin on the Mopar NSS.
At the Mopar starter you will need to run a jumper wire between the large terminal and the smaller "S" terminal.
well there you go
John do you know what the # is or what year that it fits?
that is good to know... Ron...
I still like the mopar one better
