Quite the converse of what you were attempting to illustrate....by this definition it could be argued that the best power would be made with the SMALLEST MCA possible while still providing adequate airflow to fulfil the demand if the engine at the RPM you are trying to make power.....as too large an MCA will kill velocity and inertia and require the valve to close sooner before to avoid reversion.
