Quote: Sounds like someone put a two barrel carb and a set of mufflers on it. 3 carbs-2 MSD boxs-2 fuel pumps-3 sets of plugs-cap&rotor. all been change. check valve lash 5 times ! springs look ok not that old-Just took the front of the motor apart everything on the timing chain looks great. also change it from e-85 to gas no change. timing is rock solid. 18-34 . nothing in the oil filter. compression test good 100-170 . will not rev up..not crisp and clean. What else to check- ideas..split them out !
It still the 100 year old question. Is it getting fuel and ign? sounds like you covered the ign. do you have a carb to try?
