Re: Ok so my car is 5 tenths slow
[Re: VernMotor]
#1252274
06/17/12 06:23 PM
06/17/12 06:23 PM
Posts: 1,443 central ohio
nss guy
central ohio
Cut the boot off the wire and this is what I found.
you need that get that crap off and put some "Firecore" wires on it and some TTI headers on so you don't burn up any wires. ![](/ubbthreads/images/graemlins/laugh.gif)
[Re: 383man]
#1252277
06/17/12 10:32 PM
06/17/12 10:32 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
I have an infrared heat gun. When something like this happens, i can use it to test the heat of each header pipe to see what cylinder the miss is in. Helped me to find a broken injector wire on my Daily driver.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: VernMotor]
#1252279
06/17/12 11:40 PM
06/17/12 11:40 PM
Posts: 914 tn
robnbird
tn
Sounds like someone put a two barrel carb and a set of mufflers on it. 3 carbs-2 MSD boxs-2 fuel pumps-3 sets of plugs-cap&rotor. all been change. check valve lash 5 times ! springs look ok not that old-Just took the front of the motor apart everything on the timing chain looks great. also change it from e-85 to gas no change. timing is rock solid. 18-34 . nothing in the oil filter. compression test good 100-170 . will not rev up..not crisp and clean. What else to check- ideas..split them out !
It still the 100 year old question. Is it getting fuel and ign? sounds like you covered the ign. do you have a carb to try? ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Dunnuck Racing]
#1252280
06/17/12 11:52 PM
06/17/12 11:52 PM
Posts: 3,589 Topeka Kansas
ksj
Topeka Kansas
Just glad you got it fixed,Jenni was probably getting worried!
Keith
Best Quote of the entire post!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ![](/ubbthreads/images/graemlins/haha.gif)
[Re: sunroofgtx]
#1252281
06/18/12 11:02 AM
06/18/12 11:02 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Vern, glad it was tha easy. I am back from vacation !!
Glad you found the problem Jamie and its a simple fix...
Rich I called your shop the other day to find that you guys were on vacation... I'll get back with you ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1252282
06/18/12 11:55 AM
06/18/12 11:55 AM
Posts: 2,864 IN
Irun5snd8th
IN
A tenth has been my experience in the 1/8th mile with a cylinder down from a plug wire.
AFCO, Rons Fuel Injection sponsored Dodge Challenger
Mention Street Lethal Motorsports
