Quote: had 3 coil on it now.. will do a leak down here today.. compression 120 over 170 .. that is 1 cy. has max 165-170 on all 8. I know some here do not understand 2 numbers on a compression test. you have your first hit then you second hit. Thank you all very much for the repleys
"120 over 170",,,,are you taking it's blood pressure..??
If you like drag racing, support your local track.
