Here is a variant of the linkage. Need to have the spring 13 hooked to the linkage belcrank to pull the rear of them linkage slot forward to have constant contact with the throttle pin for the full travel of linkage beginning when the throttle starts to open and all the way back. This is what governs the throttle pressure to for correct shift points.
